Movable parts
Chief
(@chief)
Movable parts
I am having problems with parts that are supossed to move. When done printing they do not, there seems to be enough clearance gap. Any suggestions?
Postato : 27/02/2017 11:15 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: Movable parts
usually you have to "break free" the parts after the print. common method is to use a rubber mallet... but it depends on the object you've printed.
if you can't get the parts loose, you need to print them with more space inbetween. you can also try to reduce the extruding width a little bit, which helps sometimes.
Postato : 27/02/2017 11:30 pm
