!!! Material settings a print surface preparation 3mm version
Josef Průša
(@josef-prusa)
Member Admin
More detailed information moved to http://www.prusa3d.com/material-guides/
PREPARING THE PRINT SURFACE AND REMOVAL OF THE OBJECTS
💡 It is important to prepare the print surface while cold. Ideally spray some ABS Juice on the surface and wipe it with paper towel. If you use ABS Juice spray on the hot surface, you will quickly have ugly buildup of ABS which can leave marks on the printed objects.
💡 Remove the objects only when they cool down to room temperature. If they are still hot, the bond with print surface is too strong and you will have to use a lot of force to remove them. This can lead to loosing the calibration of the print surface or even damage on some parts.
💡 The simplest way to completely clean the print surface is submerging it in warm water for 30 minutes. You can then simply clean the surface with towel. Next steps are one coat of glue on the clean glass and then before every print light coat of ABS Juice.Visual guide to preparing the print surface.
Founder and owner / Majitel a zakladatel
Opublikowany : 26/07/2015 6:04 pm
