        Re: Lines on top finishing layer
It's because of the square holes getting in the way. I clashes with the 45degree default infill angle.
Maybe you could try to change the angle to 0 degree or 90 degrees.
In Slic3r: Print Settings>Infill>Fill angle
                            Publié : 14/10/2017 5:20 am
Or try "concentric" as the bottom/top fill pattern.
                            Publié : 14/10/2017 7:19 pm
