Lines on top finishing layer
jwu
 jwu
(@jwu)
Hi all, can someone suggest what might be the cause of the lines on top finishing layer? Thank you.
Veröffentlicht : 13/10/2017 12:19 pm
MrMik
(@mrmik)
Re: Lines on top finishing layer
It's because of the square holes getting in the way. I clashes with the 45degree default infill angle.
Maybe you could try to change the angle to 0 degree or 90 degrees.
In Slic3r: Print Settings>Infill>Fill angle
Veröffentlicht : 14/10/2017 5:20 am
AJS
 AJS
(@ajs)
Or try "concentric" as the bottom/top fill pattern.
Veröffentlicht : 14/10/2017 7:19 pm
