Knowledge Exchange - Best 3D Print Settings
moritz.g
(@moritz-g)
Hello everybody
Is it a pain for you to spend a lot of time for experimenting on print settings until you find the best combination? This is exactly what I experienced.
For this reason, I want to collect the knowledge and experiences of the community to make 3D printing easier for each other. I started to build up a database for printer models, filament types and filament provider. The target is to share the results with you and make 3D printing easier! If you like the idea and if you are interested in the best practices from other users, it would be great if you help us to grow by sharing your experiences in return. It takes you 1-2 minutes (per setting combination - printer model, filament type, filament provider) to fill out the survey and make a big contribution to the printing community.
http://www.surveyanalytics.com/t/AI6avZOT57
Thanks for helping to build up this database!
Opublikowany : 29/05/2017 3:04 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Knowledge Exchange - Best 3D Print Settings
nice idea.... but far to perfunctory. 🙄
💡 3D print settings for the filaments are much more complex to deal with than with temperature, filament brand and layer height.
that's why there will always be big growing threads about the different problems/solutions/recommendations.... and even if i dissapoint you: it's more worth to read and understand them as setting up a quick survey !
Opublikowany : 29/05/2017 11:44 pm
Knickohr
(@knickohr)
Member Moderator
I have exacly such a database in Excel 😉
Can share settings if you're interrested.
But I agree with Jeff. It's not just that easy as it looks. There are much more parameter and tweaks to do. It also depends on your "skill level".
Thomas
Opublikowany : 30/05/2017 9:08 am
moritz.g
(@moritz-g)
Thomas
Hi Thomas
I totally agree with you and Jeff. You are absolutely right that these questions are not comparable with the information that a slicer like cura can provide. This is not the target - at least not at the moment. However, I figured out that a structured database with the most important experiences from other users would deliver great value for a big part of the printing community. The factors taken into account (nozzle temperature etc.) are limited, otherwise it would be a huge effort for the user to share it. I am still trying to find the sweet spot of how to provide valuable information and keep the effort for the user as small as possible. I appreciate every kind of help in order to achieve this.
It would be really great to view your settings. If you are interested, I can share the collected settings for Prusa Printers with you as well.
Best
Moritz
Opublikowany : 30/05/2017 10:48 pm
moritz.g
(@moritz-g)
Hi Jeff
Thanks for your input. I agree that this is a simplified version for printing settings. However, I am convinced that this level of detail can already deliver benefits to users that are new to the printer and filament. As I said to Thomas, I am still trying to find the sweet spot of how to provide valuable information and keep the effort for the user as small as possible, and I appreciate any kind of help in order to achieve this.
Thanks
Moritz
Opublikowany : 30/05/2017 10:52 pm
Knickohr
(@knickohr)
Member Moderator
My "collected settings" :
Anbieter Hersteller Bezeichnung Material Farbe Drucktemperatur Betttemperatur Profil Bemerkung
Prusa Prusa FLM-PLA-175-SLV PLA silber 215/205 55/55 Prusa PLA 1.75mm
rigid.ink rigid.ink PLA PLA rot 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA grün 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA schwarz 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA weiß 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA magenta 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA grau 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA purple 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA gelb 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA blau 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA Natur 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA trans grün 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA PLA gold bronze 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink PLA Plus+ PLA Grün 240/240 55/55 rigid.ink PLA Plus+ Klebestift verwenden
rigid.ink rigid.ink TPU TPU Natur 230/210 80/70 rigid.ink TPU Klebestift verwenden
rigid.ink rigid.ink FlexiPLA PLA Natur 245/240 70/60 rigid.ink Flexible PLA Klebestift verwenden
filamentworld FilaFlex FLX175X500ORG FilaFlex orange 240/240 50/50 filamentworld FilaFlex Klebestift verwenden
filamentworld FilaFlex FLX175X500NYL FilaFlex neon gelb 240/240 50/50 filamentworld FilaFlex Klebestift verwenden
filamentworld FormFutura PLA175XGID PLA glow grün 215/205 55/55 filamentworld PLA
filamentworld eSun ESU175X500CCUR PLA UV rot 215/205 55/55 filamentworld PLA
filamentworld eSun ESU175X500CCTB PLA Temp. blau 215/205 55/55 filamentworld PLA
filamentworld filamentworld PLA175XFOR PLA neon orange 215/205 55/55 filamentworld PLA
filamentworld extrudr MCPLA175XMTN PLA mountain 215/205 55/55 filamentworld PLA
filamentworld filamentworld PLA175XWHT PLA schneeweiß 215/205 55/55 filamentworld PLA
Herz Herz 5200641 PLA blau 225/215 55/55 Herz PLA
Herz Herz PLA creme 225/215 55/55 Herz PLA
Herz Herz 5200643 PLA kirschrot 225/215 55/55 Herz PLA
rigid.ink rigid.ink Nylon 12 Plus Nylon natur 240/240 100/100 rigid.ink Nylon Klebestift verwenden und Lüfter aus; Brim
rigid.ink rigid.ink Nylon 12 Nylon transparent 240/240 100/100 rigid.ink Nylon Klebestift verwenden und Lüfter aus; Brim
rigid.ink rigid.ink Carbonyte Nylon/Carbonfaser schwarz 270/260 100/100 rigid.ink Carbonyte Klebestift verwenden und Lüfter aus; Brim
rigid.ink rigid.ink Polycarbonate PC transparent 295/295 110/110 Polycarbonate Lüfter aus, Brim
rigid.ink rigid.ink PLA PLA feuerrot 205/200 50/50 rigid.ink PLA
rigid.ink rigid.ink FlexiPLA PLA gelb 245/240 70/60 rigid.ink Flexible PLA Klebestift verwenden
filamentworld Proto-Pasta PP175X500COF HT-PLA kaffee 205/200 55/55 filamentworld HT-PLA
filamentworld eSun PLA Temp. schwarz 215/205 55/55 filamentworld PLA
filamentworld filamentworld PLA himmelblau 215/205 55/55 filamentworld PLA
filamentworld Proto-Pasta PP175X500SST PLA stahl 225/220 55/50 filamentworld Steel
filamentworld FormFutura MFL175XCOP PLA kupfer 205/200 55/50 filamentworld Copper
filamentworld TreeD ARC175XCLY ? Ton 230/230 100/100 filamentworls TreeD Klebestift verwenden; Lüfter 20%, Brim
filamentworld polymaker PCA175XCLR PC glasklar 260/260 100/80 Polycarbonate Lüfter aus, Brim
filamentworld FormFutura EWD175XCOC ? coconut 210/200 55/20 filamentworld Easy Wood
filamentworld eSun ESU175X500CCUV PLA UV viloett 215/205 55/55 filamentworld PLA
filamentworld polymaker PCP175XWHT PC weiß 260/260 100/80 Polycarbonate Lüfter aus, Brim
filamentworld Proto-Pasta PP175X500CIN HT-PLA zimt 205/200 55/55 filamentworld HT-PLA
filamentworld 3DXTech 3DX175X500ABSESD ABS-ESD schwarz 240/240 100/100 filamentworld ESD-ABS Klebestift verwenden und Lüfter aus
rigid.ink rigid.ink ABS ABS schwarz 230/230 90/90 rigid.ink ABS Brim
filamentworld Proto-Pasta PP175X500ICE HT-PLA transparent 205/200 55/55 filamentworld HT-PLA
rigid.ink rigid.ink HIPS HIPS weiß 225/225 90/90 rigid.inkHIPS Brim
filamentworld polymaker PCP175XBLK PC schwarz 260/260 100/80 Polycarbonate Lüfter aus, Brim
Sorry, in German. But I'm German 😉
Thomas
Opublikowany : 31/05/2017 9:12 pm
