Kisslicer settings ?
christophe.p
(@christophe-p)
Member Moderator
I've seen some people here using KISSlicer with great success.
I would like to give it a go, especially to slice the top and bottom part of the Rambo-mini provided in the Improvements sub-forum.
Would you mind sharing the 4 ini files that are used by KISSlicer for the configuration ? I've seen the support file provided by Peter (PJR). I've also seen some screenshots on the same thread, but they seems to be from an older version.
I would like to start from a set of well-known working config file as a baseline and to adjust what should be specific to my configuration.
Many thanks in advance !
I'm like Jon Snow, I know nothing.
Napsal : 09/03/2016 5:32 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Kisslicer settings ?
Hi Christophe
I have attached my latest settings. Hope some of these will work for you...
Peter
Napsal : 09/03/2016 5:40 pm
christophe.p
(@christophe-p)
Member Moderator
Fantastic !
thanks a lot Peter, really appreciated ! I will try to finalize my Rambo mini based on that !
Napsal : 10/03/2016 1:09 pm
nomad
(@nomad-3)
Hi Peter,
I do not see the attachment with the settings. Would you be able to post them again?
Thank you.
Shane
Napsal : 19/08/2016 3:49 am
PJR
 PJR
(@pjr)
Hi Shane
My latest settings attached.
You will note that 4 printers are defined; ensure you use the correct printer. I am also in the process of making a few changes, so the settings are a "work in progress".
For the Mk2, I have considerably lowered the first layer speed and run the 9-point calibration at 160 degrees (bed @ 60) Also note that the material bed temp is set to 55, but that is increased by 5 degrees for the Mk2.
Peter
Napsal : 19/08/2016 10:06 am
nomad
(@nomad-3)
Hi Peter,
Thank you!! I appreciate it. I will make sure to use the correct printer. This will definitely be a good starting point.
Thanks again.
Shane
Napsal : 20/08/2016 3:12 pm
christophe.p
(@christophe-p)
Member Moderator
Thanks a lot for the update Peter, I will take the opportunity of official KISSlicer 1.5 final version to test it again.
Napsal : 21/08/2016 1:20 am
