Issues with Benchy in Slic3r
jwx23
(@jwx23)
I am having some issues getting Benchy to print properly using the default Prusa PLA settings in Slic3r with Prusa PLA (silver). Around the holes at the front of Benchy there are slightly dug in areas on one side while on the opposing side the area is nearly flat. I have attempted fix this by reducing the Speed for print moves down to 20 mm/s and the Acceleration control down to 800 mm/s^2 all with the same result. I'm uncertain what the issue is. Could it be jerk?
Napsal : 22/03/2017 6:51 am
Wirlybird
(@wirlybird)
Re: Issues with Benchy in Slic3r
Are you using a default profile for it? Like the regular .2? If you want I can print one and if it looks good try to attach the gcode and you could try it.
Napsal : 28/03/2017 8:43 pm
Wirlybird
(@wirlybird)
Another ting to try is turn him about 45 degrees in either direction then print. Sometimes it helps.
Napsal : 28/03/2017 8:58 pm
