How do you print (almost) sharp edges?
Hyperion Design
(@hyperion-design)
Hello everybody,
I wasn't able to find an answer to my question in this forum, sorry if this already has been answered.
I was creating and printing some tabletop terrain tiles, and it all looks great. But all "edges" that are going in Z-direction are quite round. So let's assume I am printing a cube: Top and Bottom have very sharp edges, but the other four are rounded.
I understand that this has to do, with the shape of the nozzle and how the printer works. But is there any way to reduce this effect?
I am working with Slic3er.
Thank you!
Napsal : 20/09/2017 12:59 pm
AJS
 AJS
(@ajs)
Re: How do you print (almost) sharp edges?
This printer is very capable of sharp corners on all sides. Print a test cube:
https://www.thingiverse.com/thing:1278865
and post a photo. It sounds like something is not set correctly.
Napsal : 20/09/2017 3:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
If you want sharp corners, you could try lowering the perimeter print speed and print the perimeters first.
Peter
Napsal : 20/09/2017 4:56 pm
