First layer has lifting within the print surface, how to fix?
Weaponsmith
(@weaponsmith)
Running single layer calibration print and the right side looks great. The others look terrible. I recently did a firmware update to the new RC, and then ran a full xyz recalibrate and z adjust (-0.400 currently).
i tried dropping pla temps to 190C but that didn't seem to do much. 210 seems better.. I then tried to raise z height, but that just made the pla not stick the pei.
Reverse side:
Opublikowany : 06/02/2017 2:53 am
gabriele.s2
(@gabriele-s2)
Re: First layer has lifting within the print surface, how to fix?
I have similar issues though not that bad. I think that the mesh leveling doesn't cancel out minor differences in height of the bed. In my case it's not bad enough that I want to try to figure it out, but it's definitely there.
- Gab
Opublikowany : 06/02/2017 4:22 am
Weaponsmith
(@weaponsmith)
Whats weird is that I've been able to print stuff with amazing first layer, but this single layer test with this silver filament is garbage. I don't know if its poor quality filament, temp settings, print speed, calibration, etc... just looking for clues how to improve it.
Opublikowany : 06/02/2017 4:30 am
eVenom
(@evenom)
Clean the bed with acetone and run the calibration print to completion. If the Calibration Print job doesn't finish it doesn't save the live z-axis tune
Opublikowany : 09/02/2017 3:56 am
