Extruder not extruding
cameron.c2
(@cameron-c2)
I currently have a RepRap Guru Prusa i3 and my printer will not extrude any filament during a print. This problem occurred right after a print where I ran out of filament during a print and so, filament was left in the nozzle and neck heated for a few hours.
I have replaced my .4 mm nozzle for the printer, a new extruder feeder with a new gear for the stepper motor, I reinstalled the marlin firmware on the arduino, and upgraded to cura 2.6.2, I installed a new stepper motor driver for the extruder stepper and adjusted the potentiometer voltage to about .6 volts, a new heater block and neck, and a new ramps 1.4 board,, and recently I just installed a new stepper motor. Unfortunately, I am still having the same issue.
The bed is leveled correctly with a glue-stick for adhesion.
I currently am printing with Hatchbox PLA with an initial layer of 190 then after that, it goes down to 185.
I have tried printing at 220 and I still am having the same issue.
Here is what my prints are looking like: https://drive.google.com/...ems/view?usp=sharing
I have read other forums and other research for help and nothing has helped yet and I assume that the actual problem is the cura software?
If you have any questions about my setup, please ask. ANY help would be greatly appreciated!
Thank you
Postato : 09/10/2017 7:09 am
AJS
 AJS
(@ajs)
Re: Extruder not extruding
Can't see you photos. Attach them to the post using Attachments.
Sounds like you have a clog in your cold break. You should heat the extruder, and push something through from either end (with nozzle out.) Or search "Cold Pull" for another method.
Postato : 12/10/2017 3:32 am
cameron.c2
(@cameron-c2)
Deeply sorry about the broken link. I have added the picture using Attachments.
I have heated the extruder and pushed something through. I even replaced the entire extruder assembly and nozzle on my printer and filament is still barely coming out. I shall try again though.
I appreciate your response.
Postato : 12/10/2017 4:13 am
PJR
 PJR
(@pjr)
Antient Member Moderator
This is an official support forum for Prusa Research s.r.o. customers.
Please contact the supplier or manufacturer of your printer for more information.
Peter
Postato : 12/10/2017 10:14 am
AJS
 AJS
(@ajs)
If the pathway through the extruder is clear:
Make sure whatever mechanism that grabs and pushes the filament is grabbing and pushing it through.
Make sure the extruder temperature is hot enough to melt the filament.
Postato : 12/10/2017 3:49 pm
