Dispaly issues in Firmware V3.0.1 on i3 Original V1
mattis.m
(@mattis-m)
I have modified Pronterface so that it shows the status of the print on the display, this way you can turn off your computer monitor on long prints (like when printing from SD-Card). This is realized with the M117 G-Code command and worked fine in Firmware 2.2.4. So I'm wondering if it is planned to not work (it just shows "USB Printing") and why otherwise a quick fix would probably fix this (I'd also do it and file a pull request but only if know that it'll be accepted).
EDIT: The same seems to happen on pause via M0 when pausing ("press button to continue is not shown but required")
Postato : 27/12/2016 9:41 pm
