Difference between Colorprint and ZHop
MrMik
(@mrmik)
What is the difference between Colorprint and ZHop in the Slicer printer settings, and how do I chose the right one?
Cheers, Mik
Postato : 11/10/2016 10:43 am
David T.
(@david-t)
Re: Difference between Colorprint and ZHop
ZHop profile has Z-lift enabled. Use it unless you want to use ColorPrint application.
Postato : 11/10/2016 10:59 am
MrMik
(@mrmik)
Thanks, David.
Is ColorPrint used for multi-color printing or what is it's purpose?
And what would be the likely problems if using ColorPrint when ZHop should be used?
Postato : 11/10/2016 11:52 am
David T.
(@david-t)
Yes, ColorPrint is used to simplify process of multi-color (layer-based) printing. But basically it does stuff which can be done by hand quite easily.
By using ColorPrint profile instead of ZHop profile you will not use Z-lift feature, which is good for eliminating scars on top solid layers caused by hot nozzle moving too close above the layer, and also for eliminating collisions of the nozzle with slightly warped or curled parts of printed object. But the same feature confuses ColorPrint application, that's why there are two profiles provided.
Postato : 11/10/2016 12:13 pm
MrMik
(@mrmik)
Thanks!
I have been printing for the entire first week of ownership without ZHop (and no color changes).
I wonder how many of my problem prints will improve with ZHop.....
Postato : 11/10/2016 12:39 pm
