Cura wont print due to not fitting the heatbed????
borgqueenx
(@borgqueenx)
Well, cura itself is showing the size of the object wich is correct compared to 123d.
See for yourself:
Now why does cura say this will not fit the mk2 heatbed?
Opublikowany : 03/11/2016 1:59 am
Nigel
(@nigel)
Re: Cura wont print due to not fitting the heatbed????
It does seem a tight fit. Check your Cura settings. Do you have brims/skirts activated in Cura? Printing that near the bed boundaries can be difficult.
Nigel
Opublikowany : 03/11/2016 4:54 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Boaz
You have skirt selected. If you don't need it, turn it off.
Peter
Opublikowany : 03/11/2016 9:23 am
borgqueenx
(@borgqueenx)
oh its brim/skirt/something. Do i need that for this print do you think?
Opublikowany : 03/11/2016 12:33 pm
PJR
 PJR
(@pjr)
Skirt is simply a line around the printed object; its main purpose is to ensure the filament is flowing properly prior to a print.
The existing Slic3r "Original" profile already prints a line at the front of the bed to do the same, so a skirt is not really required. You should ensure that Cura start GCode does the same.
A brim on the other hand is a layer (or two) joined to the perimeter of the model to help the model stick to the bed, It does not look as though you are using a brim and it is probably not required for your model.
Turn off the skirt and you should be fine.
Peter
Opublikowany : 03/11/2016 12:50 pm
