Concern with thin layers (less than 0.2mm)
frederic.b
(@frederic-b)
I have a concern when I try to print with thin layers (less or equal to 0.1mm).
I have the same concern with PLA or ABS material.
With 0.2mm layers, global aspect is quite good even if it could still be improved
But with 0.1mm layers, result is simply horrible (look at the lower area of the boat hull)
I tried several solutions : external perimeter speed, material temperature, etc... but unfortunately without succes
Other concern on the boat : In both configurations I have 2 horizontal line in the middle of the boat hull.
I don't understand the cause of this issue. Could you please help me to understand and find a solution to this issue
To print I use Slic3r with below parameters
ABS
Hot end temperature : 240°C
Thanks for your help,
Fred
Napsal : 03/12/2016 11:30 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Concern with thin layers (less than 0.2mm)
Fred
I remember seeing a video by Tom Sanladerer addressing exactly this issue. I seem to recall it had something to do with bed temperature (but I may be well wrong!).
Check out his youtube channel.
Peter
Napsal : 03/12/2016 11:38 pm
StephanK
(@stephank)
Starting at minute 22:00
Napsal : 04/12/2016 10:21 am
PJR
 PJR
(@pjr)
Stephan
Thanks for finding the link; I knew I had seen it somewhere.
Peter
Napsal : 04/12/2016 11:24 am
frederic.b
(@frederic-b)
Thanks for the link.
If I understand, I have to reduce bed temperature and add cooling. I just launch a print with bed temperature at 90°C (instead of 100°) and with fan cooling at 10%.
Wait and see
Fred
Napsal : 04/12/2016 11:39 am
frederic.b
(@frederic-b)
I just have a look on my print with new parameter.
It is better on the sides. But front of the boat is still horrible (but better than previous print).
I launch a new print with bed temperature at 85°C.
Fred
Napsal : 04/12/2016 12:27 pm
