Colorfabb NGEN settings
Nigel
(@nigel)
I printed some parts yesterday with Slicr settings provided by Prusa for 1.75 filament. Hotened 240 deg C with an heated bed of 85 deg C. I got better prints with less stringing with Simplfy 3D using supports. I find 228 - 235deg C is better for NGEN. and a heated bed of 75 deg C
Nigel
Respondido : 21/09/2016 6:53 am
Omikron
(@omikron)
Re: Colorfabb NGEN settings
I just bought about 10kg of nGen. After A LOT of tweaking and many 3D Benchy's, I've gotten the best results with the following settings for nGen:
Print Temp: 240C
First Layer Temp: 220C
Extrusion Multiplier: 1.00
Extrusion Width: Auto
Retraction Distance: 1.00
Retraction Speed: 2700
Coasting Distance: 0.50
Wipe Distance: 2.00
Top and Bottom Layers: 4
Outline Shells: 3
Infill Outline Overlap: 35%
Fan off for layers 1-3.
Fan capped at 35% for layers 4 and up, except for bridging, which is 100%. I'm considering reducing fan speed even more.
Default Printing Speed: 2400
Bridging Speed Multiplier: 50%
Some other small tweaks here and there, but those are the main ones.
Respondido : 22/09/2016 8:14 am
Nigel
(@nigel)
Thanks Babak.j I will try your settings in my future ColorFabb NGEN prints. And see how it goes.
Nigel
Respondido : 25/09/2016 3:47 am
nate.l
(@nate-l)
Thanks for your detailed settings, I just bought some of this and being a newb I am having trouble locating some of your settings in my Slic3r setup.
Retraction Speed: 2700 ------>so this is 27mm/s?
Coasting Distance: 0.50----->I could not locate this
Wipe Distance: 2.00----->I could not locate this
Infill Outline Overlap: 35% ------> i am not sure where to find this?
Fan capped at 35% for layers 4 and up------->so Min is 0 and Max is 35%
Default Printing Speed: 2400------>Where is this located in the Print Settings under Speed, there are many choices
Bridging Speed Multiplier: 50%---->I could not locate this
thanks for any help on this
Respondido : 15/03/2017 10:27 pm
Chris
(@chris-48)
Nate - the settings are for Simplify 3D.
Respondido : 16/03/2017 12:52 am
nate.l
(@nate-l)
Ah ok thnx
Respondido : 16/03/2017 1:00 am
maarten.k
(@maarten-k)
Print Temp: 240C
Wipe Distance: 2.00
Outline Shells: 3
Thanks Omikron for taking the time to post these settings. Printing my second test print (Marvin) with it and I can already see major improvement over the default Slic3r profile. Would it be possible for you to share your FFF profile for Ngen so I can match your settings exactly?
Respondido : 06/04/2017 12:01 am
sebastian.n3
(@sebastian-n3)
Hi Omikron and thanks for the work done.
Are you willing to share the FFF profile?
Thanks
Respondido : 17/05/2017 3:40 pm
ir_fuel
(@ir_fuel)
Just received some nGen samples and did a few tests
all in Slic3r Prusa edition. Printer is an mk2MMU
First test, default settings,
Second test 230 degrees (default = 240), and fan 100% for bridging
Third test 220 degrees.
You tell me which is which :p
I sent a mail to Colorfabb for help.
Respondido : 03/01/2018 8:33 pm
