Can I use a 2.85 mm filament in my Prusa i3?
[Zamknięte] Can I use a 2.85 mm filament in my Prusa i3?
Vicente Mateo Baeza Pastor
(@vicente-mateo-baeza-pastor)
Hello, I'm new here and this question may have been already asked. It's simple: Can I use a 2.85 mm filament in my Prusa i3 MK3S? If so, I'd have to change the PrusaSlicer parameters, wouldn't I?  Thank you in advance.
Opublikowany : 05/04/2020 5:35 pm
RE: Can I use a 2.85 mm filament in my Prusa i3?
you would need to change the extruder to one that would accept 2.85mm filament and you would need to configure the  firmware to drive the extruder then you would need to set up slicr profiles to match the extruder.
Opublikowany : 05/04/2020 5:49 pm
@joantabb
Ok, thank you very much.
Opublikowany : 05/04/2020 6:54 pm
@joantabb
Opublikowany : 05/04/2020 6:55 pm
