Can I move Z axis 70mm in End G-code?
bruce.k2
(@bruce-k2)
I want to move Z axis up so I can more easily clean the Hot End after the print is done. How about adding something such as G1 X0 Y200 Z70 ?
I also want to unload the filament at the end before the Hot End cools down. What G-code should I put in to do that?
I am using transparent ABS that soaks up moisture like a sponge and I want to bag overnight.
Napsal : 21/11/2016 8:07 pm
StephanK
(@stephank)
Re: Can I move Z axis 70mm in End G-code?
There should be an option in your slicer to modify script executed at the end of a print. I added a simple
G1 X0 Y200 Z200
for the end script and the print cancelled script (my printers are controlled by a Pi3 running Repetier-Server) to get the Hotend raised up from the buildplate. With respect to unloading the filament, I never tried that myself but I guess you could try a long retraction like
G1 E-100 F200
(as suggested by PjR here: http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/unload-filament-at-the-end-of-printing-t805.html )
Napsal : 22/11/2016 9:29 am
You might want to eject the filament at a higher rate to reduce the chances of leaving waste In the extruder
Napsal : 22/11/2016 5:28 pm
Carsten
(@carsten-2)
Is there a solution to prevent the z axis running over the end in tall prints? I mean it does not hurt on the prusa mk2 but is maybe still annoying.
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Napsal : 24/11/2016 11:41 am
RubenRybnik
(@rubenrybnik)
Carsten
Was wondering this myself... I think you can put the coord system into relative mode after the print is done then go from there but I haven't tried it, maybe someone else has some info though.
Prusa MK 2.25 (Downgraded MMU on MK2 with MK3 printed parts)
Prusa MK3 Kit
Napsal : 25/11/2016 8:16 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Most slicers will allow you to do something like this in the eng GCode section:
G1 F1200 X0 Y200 Z<Z+1.0> ; move bed for easy removal
Peter
Napsal : 25/11/2016 11:16 pm
Webdad
(@webdad)
I'm using the below for my S3D End script:
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
G91 ; Use Relative Coordinates
G1 Z0.6 F5000 ; Lift Nozzle by 0.6mm
G90 ; Use Absolute Coordinates
G28 X0 ; home X axis
G1 Y195 ; Move Y axis to end position
M84 ; disable motors
M107 ; turn off fan
I'd like to lift the nozzle more like 10 or 15mm and use something similar for canceled prints in Octoprint, but was also worried about a tall print trying to go past the upper limit of the printer.
Looking at the gcode wiki - http://reprap.org/wiki/G-code#G0_.26_G1:_Move - would the "S1" parameter help in preventing trying to overshoot the upper Z limit if the gantry was already near the top and tried to go past the upper limit?
Napsal : 02/01/2017 2:14 pm
Unknown ElementX
(@unknown-elementx)
Anyone come up with a solution this? I'd like to add this as the latest slicer version now ends with the head down and the bed all the way back (very inconvenient)
Napsal : 08/04/2018 6:02 pm
Guido666
(@guido666)
Wouldn't you just move to the highest z (e.g. G1 Z210.00), to avoid running over a potential print?
Napsal : 08/06/2018 11:18 pm
Martin Wolfe
(@martin-wolfe)
I tried this
G1 Z{if [layer_z] < (210-50)}{[layer_z]+50}{else} 210 {endif} F5000; if room raise Z by 50mm otherwise raise to top of Z axis
Unfortunately [layer_z] is not available in the end G-Code. If any one has a way of picking up the Z value of the last layer printed this could be made to work.
Regards,
Martin
Martin Wolfe
Napsal : 09/06/2018 5:10 am
devilhunter
(@devilhunter)
This is currently in the 1.40beta Slic3rPE end gcode
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up
in cleartext, this would be
Go up by 3cm (if there is room) to allow removing the heat bed plate easier.
Napsal : 09/06/2018 4:55 pm
