Bad corners?
Danlad1631
(@danlad1631)
Bad corners?
As you can see in the attached image, the corners are really bad. There should be a flat surface in-between he corners but it's curved.
How can I improve the corners? Is it speed related? I was printing at 50mms using S3D.
Thanks
Publié : 05/10/2016 7:07 pm
David T.
(@david-t)
Re: Bad corners?
What is your acceleration setting?
Publié : 05/10/2016 7:33 pm
Danlad1631
(@danlad1631)
Re: Bad corners?
Good point, I'll have a look tomorrow at work and report back.
What would you recommend?
Publié : 05/10/2016 7:37 pm
David T.
(@david-t)
Re: Bad corners?
I'd recommend the same settings as provided in Slic3r profile, but this is quite impossible as S3D cannot work with acceleration control. There is a workaround, you can use post-processing script for adding acceleration setting into generated gcode. It was discussed on this forum earlier. http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/improving-print-quality-on-corners-t1494.html#p11571
Publié : 05/10/2016 8:13 pm
