Any ideas with support material?
fox.c
(@fox-c)
I just switched from Slic3r to PrusaSlic3r because I heard that the support materials were better. I am trying to print this "Leg_Left_Half_001" and tried with Slicer but as you can see, the settings werent so good as the support was fused to the build. I currently have the Pattern Spacing as 5mm, Pattern angle 0, Interface Layers as 4 layers and Interface pattern spacing 4mm. Any ideas as to help with the support material would be great!
Publié : 06/08/2017 7:55 pm
AJS
 AJS
(@ajs)
Re: Any ideas with support material?
Make sure your Contact Z distance is 0.2 (or even 0.25), and the XY separation between an object is large enough. I use 2mm. I would try with less or no interface layers for a part like this.
That said, supports are an art form, and it will take a while to get your settings correct. I will admit to only being 75% there. Some people like support better in other Slic3rs. Hopefully they will chime in here for you.
Publié : 06/08/2017 8:01 pm
