Any Gcode or PE Slic3r option to Increase Flow Rate for 1st Layer?
david.b14
(@david-b14)
Hello,
For big parts I have been using OctoPrint to manually increase the flow rate to 115% for the first layer.
Is there a option in PE Slic3r to do this or is it easy to add some Gcode that would do the same thing?
Thanks in advance,
Dave
Veröffentlicht : 12/03/2017 2:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Any Gcode or PE Slic3r option to Increase Flow Rate for 1st Layer?
David
I haven't seen such a setting in Slic3r, but this can be done in other slicers (KISS has 2 ways of increasing the 1st layer volume).
Peter
Veröffentlicht : 13/03/2017 9:37 am
