Advice for Prusa use for electronics enclosure
franco.l
(@franco-l)
Hi everyone. A complete novice here. Don't have a Prusa yet but getting my hands on one soon (expect a jump in Australian consumers before July thanks to tax reforms) for electronics enclosures. Anyone got experience with this? Obviously has to be non-conductive. I'm looking at PET.
In particular, which filament that the Prusa supports would you recommend? To be more specific I want to build an enclosure for a MIDI mixer. Non-toxic would be a bonus but I don't want it to cost too much.
Adios and regards,
Franco.
Publié : 29/04/2017 9:14 am
james.o7
(@james-o7)
Re: Advice for Prusa use for electronics enclosure
how hot will this enclosure get?
You have to worry about creep for long exposures to high temperature
Publié : 29/04/2017 4:46 pm
franco.l
(@franco-l)
It's an Arduino project. I've been using it in an open environment where the heat has been easily escaping and it's roughly ambient. Within an enclosure, especially a tight one, who knows yet. There are some components that do get fairly warm so I'll watch out for this. It's something I haven't factored in yet but should've, especially over long exposure. Perhaps I should make sure there'll be sufficient heat/air flow above certain areas, maybe even add a fan as worst case scenario.
Cheers.
Publié : 29/04/2017 6:59 pm
james.o7
(@james-o7)
I would make sure it has lots of slots and openings for air, similar to the enclosure the Prusa printer uses. I would use ABS or over higher temperature plastics. If adding lots of slots not an option then you must add a fan and have forced air draft.
Publié : 29/04/2017 7:37 pm
