ABS + MK2 Kit
Dear,
With PLA i have no issues, everything is nice.
Just started to print with ABS, have to make go pro rig 360 from ABS fore sure.
I have printed PINDA cover from downloaded code - ok. (its a pity that there is no more code for ABS from PRUSA like in PLA 😳 ) just for test issues, MK1 had several but MK2 without ABS...
During print i have almost same issue with corners uplift
Printed 3 times with different infix and nearest seam position. Different temps with 100 and 105.
BRIM usually picks out after 4-6 layers...
Please help 😳
Opublikowany : 14/09/2016 9:41 am
Re: ABS + MK2 Kit
I would try less infill and different type (honeycomb). Too much linear infill increases forces causing warping.
Opublikowany : 14/09/2016 10:29 am
