        10x10x10mm cube almost good
Hi everyone,
I just printed a 10x10x10mm cube on 0.05 resolution with 25% infill. Dimensional accurracy is actually spot on, with the exception of at the bottom. The bottom has a slight elephant foot. The top layer also has some small holes.
The sides show some blobs and zits. Do you guys think there is room for improvement?
Here are some pictures:
 http://imgur.com/a/7PCHO
                            Posted : 26/03/2017 1:30 pm
                    Re: 10x10x10mm cube almost good
Yeah, the Prusa can do better still. Check this site for hints what you could try to optimize:
 https://www.simplify3d.com/support/print-quality-troubleshooting/
                            Posted : 27/03/2017 2:19 am
elephant foot is probably because you are squishing your first layer too much. run the Z calibration and print the calibration print to adjust it in the live z tune
                            Posted : 27/03/2017 2:22 am
