X - Button frustrations
Witzel
(@witzel)
ohh please tell me, short of taping it, gluing it, or desolder the damn button how do i remove its function, or reprogram it ?
It wold be nice if it worked as a return button for the menu system, not a reset funktion 😳
Me and my kidz have testet it several times, it works flawless, but the funktion is hopeles.
So is it a hard reset og can it be reprogramed ?
Best regards
Witzel
Opublikowany : 08/01/2018 9:04 pm
stahlfabrik
(@stahlfabrik)
Re: X - Button frustrations
You have not needed the button yet? I have needed it several times whenever something stupid happens. It is great so just get used to it
And can you reprogram it? I do not know (the firmware is open source). I think it might not, because it might be a physical connection to the "Arduinos" reset pin.. But you could take out the cable from the button to the EINSY pin header.
I would NOT recommend that.
Opublikowany : 10/01/2018 2:46 pm
HackMonkey
(@hackmonkey-2)
I suppose you could always print a new cover with the button filled in, and just a hole centered over the hardware button. Then you couldn't press it accidentally, and could still reset with a paper clip or such.
Opublikowany : 11/01/2018 11:39 am
LordGarth6
(@lordgarth6)
It's a hardwired function straight to the board. So you will have to desolder it or remove the pin from the cable or make a new cover. The einsy board has extra function pins I think so u could program a function to a button wired to that.
Opublikowany : 11/01/2018 12:53 pm
