Very loud noise and bad vibrations on Z-Axis
matthias.h3
(@matthias-h3)
Hello,
My printer(kit) is calibrated and a test print works also good.
But when i move z-axis up it makes a horrible noise and the printer is vibrating very strong.
When i move down it is even worse. Something is wrong.
Please see this video:
https://vimeo.com/259131730
What can i do? 😕
Thank you for your help!
brgds, Matthias
Posted : 08/03/2018 11:05 am
schichtenmacher
(@schichtenmacher)
Re: Very loud noise and bad vibrations on Z-Axis
same here since the last firmware.
with older firmware i dont have this problem
schichtenmacher on instagram
Posted : 08/03/2018 11:27 am
matthias.h3
(@matthias-h3)
ok, interesting.
But i did not do any update.
Posted : 08/03/2018 12:13 pm
Ewout
(@ewout)
Same here, been there since day 1. I can mitigate it to a large extent if I squirt some oil into the Z-axis bearings. I think that reduces the vibrations that makes something else resonate but haven't found out what part exactly.
Posted : 08/03/2018 12:24 pm
matthias.h3
(@matthias-h3)
I also tried some oil but without success! Nothing changed.
Posted : 08/03/2018 12:25 pm
jweaver
(@jweaver)
Is that not the PSU rattling?
Posted : 08/03/2018 12:47 pm
matthias.h3
(@matthias-h3)
no, i think it is not the PSU rattling. It comes from the z- spindles.
But this was not on my first 2 prints. There was everything ok.
But at the third print this problems come. In printing mode you don´t hear that noise. Only when you move fast. (for example: during calibration)
And you can feel the mechanic vibrations.
Posted : 08/03/2018 12:55 pm
jweaver
(@jweaver)
The PSU rattle is well documented.. Its caused by a plastic sheet of insulating material which rattles at certain frequencies.
Some people have poked things through the grill to secure it.. I am personally going to open up my PSU and "stick" it to the case so it doesn't rattle.
Posted : 08/03/2018 1:02 pm
RH_Dreambox
(@rh_dreambox)
Loosen the screws that hold the Trapezoid nut.
If tightened too tight, the nuts may be slightly skewed to the motor shaft and you will have that sound.
Posted : 08/03/2018 1:20 pm
matthias.h3
(@matthias-h3)
ok, thank you for that hint! That sounds logical.
I will try it when i am at home in the evening.
Posted : 08/03/2018 1:22 pm
Domo890
(@domo890)
I had this for a while... The issue for me was that the printed plastic cover for the LCD was loose, just press the front to clip it back on.
I also released why this was happening, I was not pressing the button but pinching it with one finger behind the cover. So occasionally I had been losing the cover off and allowing this to vibrate, but it was always worst during mesh bed calibration.
Maybe you should try this too.
Posted : 08/03/2018 1:45 pm
Coyoteran
(@coyoteran)
Thanks. That fixed my loud Z.
Trevor
Posted : 18/04/2018 5:29 am
