[Zamknięte] Temp tower prebuilt for MK3
ben.c5
(@ben-c5)
warning - do not use this gcode on any printer that is NOT a Prusa MK3, it was sliced in Slic3r Prusa Edition for the Mk3 and modified to change temp as it rises to each bridging section. if you use it on any other printer it can cause errors or damage, as the gcode is formatted specifically for MK3
https://drive.google.com/open?id=1IMIIUmJXZX4nPxIRDtfKKNJCzo3VEB7v
tests 240-180 in 5 degree increments, with bridging at each temperature range. the original model (without temp change code) is available here
Opublikowany : 11/02/2018 5:02 am
ben.c5
(@ben-c5)
Re: Temp tower prebuilt for MK3
after initial print, i can report that machine jams when attempting to go to 190 with Prusa PLA in silver. Also for information, on this initial print the bridges were closest to spec at the 225 temp
Opublikowany : 11/02/2018 8:51 am
Terb
 Terb
(@terb)
I got the same jam at 190c with prusa PLA. While using a temperature tower is there a risk of getting a bad clog in the nozzle? I want to try it again on some hatchbox PLA but I am a bit worried it could cause problems. This is my first printer.
Opublikowany : 17/02/2018 9:32 pm
michael.a35
(@michael-a35)
It would be great to trouble shoot this because MK3 gcode tower is so useful.
edit: also, a temp tower gcode should definitely be in the prusa starter / test print set.
Opublikowany : 17/02/2018 9:39 pm
zachary.l5
(@zachary-l5)
(realize this is an old thread, but it's linked to in a couple places)
I think one way is just to go in with a text editor and change the M104 commands for the lower temps. You're looking for e.g. "M104 S215" (which I pulled from the header block, but it happens every temp change). Just bump the low temp ones up. Also, this gcode seems to spike from 210 to 240 without pausing, so you might consider adding an "M109 S240" instruction after that spike (I'm about to play with this now).
Opublikowany : 09/05/2018 11:36 pm
MTJC
 MTJC
(@mtjc)
Printer is not jaming at 190C....the firmware prevents extrusion if it reads a hot end temp less than 190C.
Opublikowany : 14/05/2018 1:20 pm
Pat.Bellavance
(@pat-bellavance)
Hi! I was looking for a temp tower for the Mk3 and stumbled upon this thread. I know next to nothing about gcode except that is what I export in order to print. (Still a newbie here).
Has there been any modifications done to the original gcode at the start of the thread to just remove the lower values since the printer won't work with them anyway?
Opublikowany : 19/05/2018 1:26 pm
montejw360
(@montejw360)
Keep getting a preheat error at z 2.75 , just starting the bottom of the first leg layers, about 1.5mm above the base.
Opublikowany : 08/12/2018 9:00 pm
