So when is filament jam detection coming?
jake.m3
(@jake-m3)
A pretty useful feature, that was supposedly advertised?
Well its not here "yet".. ❓
Postato : 07/03/2018 9:58 pm
Peter L
(@peter-l)
Re: So when is filament jam detection coming?
It's here, just a little too sensitive and prone to false alarms. It's turned off by default but you can turn it back on in the Tune menu.
Postato : 08/03/2018 1:13 am
jake.m3
(@jake-m3)
Thats filament runout detection, not the same thing.
Postato : 08/03/2018 10:07 am
francesco.s
(@francesco-s)
Looking at the code, it should in theory work the same whether there is a jam or a runout... Have you tried "manually jamming" the filament to see if it works?
Postato : 08/03/2018 3:06 pm
Peter L
(@peter-l)
It is actually the same thing. The optical sensor is looking for movement in the filament, and triggers a pause when it doesn't see movement when movement is expected. That can be caused by either a jam or runout.
Postato : 08/03/2018 6:13 pm
jake.m3
(@jake-m3)
Have any of you been to the FB prusa group and see how many jams there are? and no it does not work, try it yourself.
Postato : 08/03/2018 7:29 pm
