Setup wizard consistently crashes
cornelius.m
(@cornelius-m)
Hi, I have the following problem:
I bought a new pre-assembled i3 mk3, unpacked it, plugged it in and hit "... guide you through the setup process -> Yes".
Then the extruder cooler powers up and the screen briefly shows "Original Prusa i3 Prusa resarch" and then it jumps back to "Hi, I am your Original Prusa i3 printer. Would you like me to guide you ..."
I also tried:
Selecting No for the setup wizard
Installing the firmware to 3.1.2 and selecting Yes and No
Downgrading the firmware to 3.1.1 and selecting Yes and No
Upgrading to 3.1.3 and selecting Yes and No
No luck and the same error in all cases.
Any help would be much appreciated.
Best
Cornelius
Respondido : 27/03/2018 1:23 pm
cornelius.m
(@cornelius-m)
Re: Setup wizard consistently crashes
Here is a short video of the problem
Respondido : 27/03/2018 1:38 pm
RH_Dreambox
(@rh_dreambox)
Check if there is something against the reset button located under the steering wheel. There may be something stuck there or the display is not properly mounted.
Or is it you who press the reset button to confirm the selection in the menu? In this case, only press the round knob ❓ 😀
Respondido : 27/03/2018 1:54 pm
cornelius.m
(@cornelius-m)
Yep, that would be me. O_o
Assumed it was the confirm button.
Thx for clearing that up.
Respondido : 27/03/2018 2:10 pm
