Raspberry Pi Zero W Not Connecting to MK3
Phaser3D
(@phaser3d)
Have installed this file on to my Pi Zero - https://www.prusa3d.com/download-prusaprint
I then connected and setup succesfully on wifi.
However in connection part it will not connect to the printer. It says "Unhandled communication error
The was an unhandled error while talking to the printer. Due to that OctoPrint disconnected. Error: Failed to autodetect serial port, please set it manually."
Any suggestions? The manual listed here needs more steps 🙂 - http://manual.prusa3d.com/c/Octoprint_for_Original_Prusa_i3_MK3
Another Q. My version seems to be 1.3.4, is it save to auto update to 1.3.6 or stay on 1.3.4
Opublikowany : 19/02/2018 5:14 am
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Re: Raspberry Pi Zero W Not Connecting to MK3
Hi Rhys,
the PrusaPrint (modified OctoPrint) was tested many times and should be working without a glitch. Please try to download the image again, use different MicroSD card, do not apply any modifications to the PrusaPrint and if the issue still persist I'm almost sure it will be an HW problem.
Assembly manuals
/ Knowledge Base
Opublikowany : 19/02/2018 2:14 pm
Phaser3D
(@phaser3d)
Hi, I found the issue, it seems i downloaded wrong image, it was a prusa one however must be for rasp pi 3 or something.
I reloaded the correct ZERO pi image for mk3 and everything connected and worked with custom profiles already loaded. Thanks!
Opublikowany : 20/02/2018 10:04 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Great! I'm glad to hear you've solved the issue 😉
Assembly manuals
/ Knowledge Base
Opublikowany : 21/02/2018 3:38 pm
