Prusa i3 MK3 Nozzle?
RobertB67
(@robertb67)
Will the MK3 still use E3D V6 Nozzle? Just want to order some extra nozzles as I wait for the printer.
Looking into maybe the Olsson Ruby Nozzle.
Napsal : 17/11/2017 3:29 am
dimitri.s
(@dimitri-s)
Re: Prusa i3 MK3 Nozzle?
I would like to know this as well as I am also considering buying the Olsson Ruby Nozzle as i would like to experiment with abrasive filaments.
Napsal : 17/11/2017 10:54 am
surfgeorge
(@surfgeorge)
I asked support:
it is the same hotend - E3D V6 - just the ptfe tube and heatbreak are slightly different (it uses these components from the multimaterial version of the hotend)
So the nozzle is the same.
Napsal : 17/11/2017 12:24 pm
The Plastic Shed
(@the-plastic-shed)
I've been down a similar path, I need to order some nozzles so I also asked this. I also intended to replace the hot end itself with the plated copper version for better temperature stability but was advised against doing this by support - not sure why. I don't mind if it takes longer to heat if it is more stable.
I'll be running basic calibration and getting a feel for the printer using what comes but the nozzle won't be in there long, I intend to use 0.25, 0.4 and 0.6 sizes and definitely harder than the standard, though I'm not sure I can justify the Ruby. It would be nice if such optional extras were made available at purchase time.
I'm also planning to build a complete additional V6 hot end from E3D with the higher spec plated block and also PT100 - then I'll see what the difference is. I'm not sure why they would have selected to use parts from the multi material hot end, don't understand the reasoning behind this.
Napsal : 17/11/2017 2:24 pm
Jonathan Kayne
(@jonathan-kayne)
MatterHackers is having a Blue Friday sale, and they have the Olsen Ruby Nozzle at a pretty good discount. I think its at $75 on their site (retail at $90).
Just in case you want to get one.
Jonathan Kayne, KM4CFT
Virginia Tech Class of 2021 - Electrical EngineeringCreator of the CFT1 Transceiver"I am always thinking about making. My future begins when I wake up and see the light." - Miles Davis
Napsal : 17/11/2017 4:55 pm
Bill
 Bill
(@bill-3)
I have no experience with the copper hot end, but after a PID tune using the printer firmware, my temperature fluctuations drop to almost non existent. You can also add a silicone sock which helps avoid the dreaded blob incidents and also helps with the temps.
Napsal : 17/11/2017 7:14 pm
The Plastic Shed
(@the-plastic-shed)
Which is probably why I was told it simply wasn't necessary, so I likely won't bother unless I encounter issues at higher temps.
The harder and larger nozzles (0.5+) however are necessary if you want to play with Carbonyte type materials, I doubt a brass nozzle would last long with it.
It seems that the socks aren't really recommended - at least that's what it says on one of the FAQ's here.
Napsal : 17/11/2017 7:44 pm
Christopher Tilley
(@christopher-tilley)
It uses an E3D V6 Hotend so yes. I ordered a Olson Ruby in .6mm. Abrasive filaments do better with a slightly bigger nozzle. The olson is supposed to be E3D V6 compatible.
Napsal : 17/11/2017 8:29 pm
RobertB67
(@robertb67)
how sure are you on the "Abrasive filaments do better with a slightly bigger nozzle .6mm"?
I guess I'll get the Olson Ruby .4mm and see if Santa brings me a Olson Ruby .6mm for x-mas/b-day 😀
Napsal : 22/11/2017 2:32 am
RobertB67
(@robertb67)
Just checked MatterHackers site and still listed at $90, where did you see it listed for $75 on the site?
Napsal : 22/11/2017 3:17 am
Christopher Tilley
It was a one day sale. The price showed up at checkout after you typed the coupon code.
Napsal : 22/11/2017 3:29 am
keithywhites
(@keithywhites)
just purchased some socks from e3d. these are awesome and I dont think anyone else makes them:
https://e3d-online.com/v6-socks-pro-pack-of-3
Napsal : 22/11/2017 5:23 am
imod.systems
(@imod-systems)
Are you modifying it to fit around the p.i.n.d.a. probe?
Napsal : 22/11/2017 1:45 pm
rufflez
(@rufflez)
These fit the e3D hotend snugly. The PINDA probe is off to the side. The closest thing these may interfere with is the plastic behind the fan in front of the hotend. Hasn't posed a problem yet for me.
Napsal : 23/11/2017 7:10 pm
