Problem with fit test
Bas
 Bas
(@bas-2)
I recently assembled my MK3 and figured I'd try printing this fit test to figure out the printer's tolerances. After printing, I noticed that none of mortices actually fit on the tenons. I guess the printer is printing too much material, but I can't figure out why or what to do about it. Any ideas, anyone?
Veröffentlicht : 11/02/2018 7:45 pm
bryan.j5
(@bryan-j5)
Re: Problem with fit test
Check the basics first.
Is it extruding the correct length of filament on a manual extrude? Try marking 4 or 5 cm on the filament and extrude the same.
Is the filament diameter correct in the slicer? Measure with a micrometer if possible at multiple points on the filament.
Which slicer are you using?
Bryan
Veröffentlicht : 12/02/2018 7:41 pm
