Prints problems and extruder freezing
eee.e
(@eee-e)
Hello I'm having some problems with my prints.
https://imgur.com/a/R1mbW
The filament layers doesn't attach well, i tried to adjust the extruder height but for some reason i can't fix the issue. Mind, i have printed the same object before and calibrated the extruder right with no problems. the bug started after i changed filament and went back to the one i'm using.
I've noticed another problem with my printer, here's a video:
https://streamable.com/g1gqg
The extruder engine isn't running smoothly and it's really hot, at last 60*+
Opublikowany : 11/03/2018 8:42 pm
thrawn86
(@thrawn86)
Re: Prints problems and extruder freezing
that sound is the extruder gear slipping, so something is causing a lot of resistance to the filament. Either nozzle not hot enough, not enough tension on the spring, super lower nozzle clearance or a partial jam somewhere. It will normally get pretty hot, I've measured mine over 80c before.
can you make it through first layer calibration okay?
Opublikowany : 11/03/2018 10:09 pm
joseph.l6
(@joseph-l6)
Keep in mind my eyes are nearly 50 this year, but from the video it looks like the Hobb gear is not inline with the filament path
Gear ||
Filament ||
Opublikowany : 11/03/2018 10:49 pm
eee.e
(@eee-e)
Calibration run fine without the gear slipping, i notice it only start doing after 1hours+ of printing . I'm also using a big calibration sheet object i found online: at -0.285 the layer breaks while at 0.300 it start dusting
Opublikowany : 11/03/2018 10:57 pm
