Printer doesn't stop when the filament runs out:
jonathan.h8
(@jonathan-h8)
Hi All,
Quick question, i was about an hour into printing a file from the SD card when the filament unfortunately snapped. This was due to a tangle on the spool.
Rather than try to intervene, i thought i'd wait for the sensor to pick-up on the fact that no filament was in the extruder and prompt me to insert some.
The printer never stopped and carried on printing even when it was completely out of filament. No errors show up on self-test, everything is on the bored as it should be.
Any ideas what might have caused this?
Opublikowany : 17/12/2017 3:25 pm
tomas.h3
(@tomas-h3)
Re: Printer doesn't stop when the filament runs out:
Did you enable the filament sensor? It was turned off by default. Haven't tested it's functionality yet myself though...
Opublikowany : 17/12/2017 3:27 pm
jonathan.h8
(@jonathan-h8)
Hi, I wasn't aware you could turn it on/off. Where can i look for that?
Opublikowany : 17/12/2017 3:32 pm
ibn
 ibn
(@ibn)
according to the manual in the settings (see pg. 30 f or pg. 62 in Version 3.1 of the handbook in the downloads section)
Opublikowany : 17/12/2017 7:22 pm
jonathan.h8
(@jonathan-h8)
Thanks, yes I found it!
Switched it on now!
Opublikowany : 18/12/2017 8:46 am
