Print time difference
david.h61
(@david-h61)
Just started to use my MK3 when slicing with prusa control the estimated time is about 50% of the actual print time. How do I get this to be closer?
Opublikowany : 30/03/2018 5:35 pm
Peter L
(@peter-l)
Re: Print time difference
Are you printing in Stealth Mode? Stealth Mode significantly increases the print time.
Opublikowany : 30/03/2018 6:59 pm
stephen.h14
(@stephen-h14)
I have the same problem. Not quite double for me. Had a print this morning that said 2hr15min that took 2h45min. I don't believe mine is in stealth mode but the print times are noticeably longer than the estimates in the slicer. I type the print time at the end of my file name so I just go back and edit it with the actual time so I know for next time I print that file.
Opublikowany : 30/03/2018 8:14 pm
LittleNeutrino
(@littleneutrino)
printing in normal mode i have also seen this. This is not my first 3D printer so i have learned to just ignore the estimated times as i have never seen them be accurate.
Opublikowany : 30/03/2018 8:46 pm
david.h61
(@david-h61)
I am not printing in stealth mode
Opublikowany : 30/03/2018 11:43 pm
ibn
 ibn
(@ibn)
Slic3r 1.39.1 calculates the print time very accurately
Opublikowany : 31/03/2018 1:07 am
Olef
 Olef
(@olef)
I too have found this, it works very well
Opublikowany : 31/03/2018 1:12 am
