Perimeter delamination with Slic3r and innoPET
Hi All,
I normally use S3D but have found previously that slic3r is better for dimensional accurate parts but I'm a bit stuck......
Slic3r 1.39.1
FW 3.1.1
InnoPET printing at 220c (as per manufacturer spec)
perimeter speed 25mm
I have a problem with the outer perimeter delaminating from the rest of the print, I've tried upping the extrusion width from 0.45 up to 0.55 and also tried upping the extrusion multiplier, but both of these still result in the outer perimeter not being fully bonded, so I can pick it away with a knife. This only seems to be a problem with the outer perimeter on internals, so in the image the cylindrical hole has delaminated but the outer square perimeters are bonded well.....
Any ideas what else to try?
Thanks!
Re: Perimeter delamination with Slic3r and innoPET
increase overlap from 25% to 30% see if you improve.
âOne does not simply use a picture as signature on Prusa forumsâ
if you have a look at the g-code in the slicer - is the distance between the parameters of the opening (the circular ones) different from the distance of the outer perimeters (the quare ones)?
