MK3 Printing speed
stevQ
(@stevq)
MK3 Printing speed
Hello everyone,
I was wondering what speed you guys use successfully on MK3 printers. Normal Slic3r Config is 50mm/s, but even on MK2s I could reach a good 60-70 mm/s at 0,2 layer height without much of quality issues. I am now printing my first parts on the MK3 and slowly adjusting the settings for best quality, but wanted to know what you guys are using =)
Hope to achieve around 80mm/s!
Postato : 25/01/2018 12:38 am
Paul Meyer
(@paul-meyer)
Re: MK3 Printing speed
I tend to run 70-90 for PETG, 90-120 for PLA. Depending on layer height and other slicer settings, you should be able to go much faster than 80.
I still tend to slow down to 80 or even slower for first layer or for the outermost perimeter.
Postato : 25/01/2018 12:49 am
HackMonkey
(@hackmonkey-2)
On big open areas, where the printer can really open up on straight lines. I have seen Slic3r PE & Prusa Control both kick out gcode running 184mms for PLA! and 122mms for PETG! In both cases it printed perfect, and I was even able to turn the speed up to about 125% more before the Bondtech started skipping. Assuming that it was actually the heater that couldn't keep up.
The MK3 is FAST!!!
Postato : 25/01/2018 7:49 am
marco.b5
(@marco-b5)
Could someone please post the slic3r settings in the speed section for a reasonably fast print speed for PLA? I'm sorry for my newbish question but I guess I learned on Cura where I can put in the overall print speed I'm using and it auto generates the remaining speed values. Guess I still have a lot to learn......
Postato : 21/03/2018 3:15 am
alan.e2
(@alan-e2)
If you install Slic3r PE it has pretty good speed settings to start with by default (they've been updated) for MK3. Here are the defaults in the Speed section:
Older version of Slic3r PE had settings that were way too fast but it's been updated.
Postato : 22/03/2018 7:16 pm
