Mk2S to Mk3 upgrade
Neil S
(@neil-s-2)
Mk2S to Mk3 upgrade
If I buy the full upgrade kit, Use the motors & LCD out of my old delta printer, with new lead screws, 8mm rods & bearings, print the MK3 parts. Do I end up with a new Mk3 and keep my Mk2s? Or will I need any other parts?
Postato : 20/10/2017 3:39 pm
Asraff Amzani
(@asraff-amzani)
Re: Mk2S to Mk3 upgrade
yeap, that is the rough idea, you just need to have extra 5 stepper motor and lcd panel, you will have mk2s and mk3
Postato : 20/10/2017 3:49 pm
DarthMuffin
(@darthmuffin)
I'm kind of wondering why the whole new hotend for the upgrade? Couldn't they just replace the heater cartridge with a 24v version and save $50 or so?
Postato : 21/10/2017 7:51 pm
It is often difficult to remove the ptfe tube, heater or thermistor. A new unit ensures this is not a problem.
With the redesign of the extruder. It is likely fthat the ptfe tube needs to be a different length.
When i tried to change my ptfe recently. I failed miserably. Luckily i had the remains of a previous extruder. And could scavenge the heatsink
Regards Joan
Postato : 21/10/2017 9:21 pm
