is there any audible alarm onboard or installable?
ben.c5
(@ben-c5)
I want audible alarm/buzzer for print complete, preferable to be able to trigger via gcode also for inserting magnets or other objects midprint. does this already exist? Is there a way to trigger it? I know the machine has some simple speaker onboard as it triggers in some menu process (filament change process when prompting for did new filament came out yet, I believe makes a brief tone)
Opublikowany : 19/03/2018 6:17 am
ben.c5
(@ben-c5)
Re: is there any audible alarm onboard or installable?
incase anyone else is looking, I find it after google search and test it work
http://marlinfw.org/docs/gcode/M300.html
Opublikowany : 19/03/2018 6:21 am
ben.c5
(@ben-c5)
also, imperial march, already figured out by someone else
http://forums.reprap.org/read.php?1,236755
Opublikowany : 19/03/2018 6:24 am
ben.c5
(@ben-c5)
you can insert it in Prusa Slic3r edition in "print settings" under "End G-code" to have it automatically added to end of every print
Opublikowany : 19/03/2018 6:26 am
