High Frequency audable tone from part coolinf fan
Whitedrag0n
(@whitedrag0n)
All,
Since day one of building my MK3 i have noticed a high pitch tone comming from the printer. I did not have a clue where it was comming from but tonight i discided to investigate.
The printer was working fine and printing excellently however the tone was bugging me and i want my mk3 quieter than it already is.
I thoiugh the coolinf fan was the souce of the noise so i fired up pronterface and fired a bunch on M106 commands at the fan inorder to see if the tone changed with diffrenf values
Low and behold. I could change the tone based on the value used.
This leads me to suspect that the cuase of the problem is the freqency of the PWM.
So investigating the configuration.h i have found the following options
//#define FAST_PWM_FAN
//#define FAN_SOFT_PWM
#define SOFT_PWM_SCALE 0 this is already enabled.
This is where i need you help.
Does anyone know if i enable FAST_PWM_FAN will this only effect the part cooling?
Any recommendations?
Does anyone elese have this issue?
Napsal : 06/02/2018 9:37 pm
imod.systems
(@imod-systems)
Re: High Frequency audable tone from part coolinf fan
this was reported as a bug to the developers on the github: https://github.com/prusa3d/Prusa-Firmware/issues/460
They mentioned modifying the pwm frequency. Maybe ask there?
Napsal : 06/02/2018 10:04 pm
