FW 3.1.1 to FW 3.1.2 issues and concerns
I see postings that 3.1.2 is Final and postings 3.1.2 is RC1 which is it?
FW 3.1.1 performs XYZ Calibration without issue FW 3.1.2 says X/Y is slightly askew which is correct?
If the printer is Slightly askew how do you fix it?
FW 3.1.2 does not seam to give a constant layer during the live z adjustment, some areas squished others not and the corners all have to much material (blobs)
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Postato : 07/03/2018 6:01 pm
