Flash Air versus Power Panic
JMcK
 JMcK
(@jmck)
I had a nice print going today from my Flashair when the power failed. OK so ready or not, time to test power panic.
When the power came back on the MK3 offered to resume, so far so good.
It warmed back up moved into position and nothing.
I got back to the main menu which said there was no SD card.
I pulled the card an re-seated it and all was well except for the now unrecoverable print.
So is this a fluke, one-time fail, or is there something not-quite compatible with Flashair and startup after a power fail?
When someone asks you if you're a god, you say, "YES!"
Veröffentlicht : 24/03/2018 2:08 am
x50arm
(@x50arm)
Re: Flash Air versus Power Panic
I would say a fluke. I have not had trouble with power panic not working with flash air, but it did fail to resume once with the normal sd card.
Veröffentlicht : 24/03/2018 12:33 pm
