Filament supplier in the UK
patcooper
(@patcooper)
Mk3 will be my first printer, there seem to be many filament suppliers in the UK but I presume they are not equal. Any recommendations ?.
Opublikowany : 24/11/2017 6:17 pm
MrSpectacle
(@mrspectacle)
Re: Filament supplier in the UK
I've had good success with the PLA from Rigid.ink at least 🙂
Opublikowany : 24/11/2017 6:57 pm
Filamentive is based in west yorkshire. And produced good filament
Regards Joan
Opublikowany : 24/11/2017 7:20 pm
The Plastic Shed
(@the-plastic-shed)
I can second rigid ink but if you're after the cheapest then they aren't for you, their ABS, ASA, PETG and Carbonyte are all good, depends what you're looking for in a filament and what you're printing. If a quality is something you value then they are the go to supplier in the UK for me but I don't print for the sake of and use mine mostly to support my RC model and electronics habit.
Before rigid ink I tended to buy off Amazon, I still do for PLA which I use for prototyping only, Primaselect and ICE are both OK, I've tried a few no names and once the printer is dialed in the results don't vary much.
Opublikowany : 24/11/2017 7:31 pm
Bavaria3d
(@bavaria3d)
E3d edge works pretty good for me. Thomas Sanladerer did some great filament reviews, I´ll put in a link:
https://toms3d.org/tag/filaween/
i3 Mk3
Engineering Student
Opublikowany : 26/11/2017 4:32 pm
Olef
 Olef
(@olef)
I've been using Filaprint.com. UK based, good filament, buy two or more rolls gets free next day delivery.
Opublikowany : 27/11/2017 1:05 pm
The Plastic Shed
(@the-plastic-shed)
Wrong address there Alf
http://shop.3dfilaprint.com
Opublikowany : 27/11/2017 2:09 pm
Olef
 Olef
(@olef)
Your right! Thanks Neil 🙂
Opublikowany : 27/11/2017 2:42 pm
Nalfy
(@nalfy)
www.spannerhands.co.uk
They sell fillamentum PLA and ABS at really good prices, £18 per roll. Fillamentum is really good to print with
Rigid ink I would avoid, the filament is ok but nowhere near worth what they charge for it.
3D filaprint I also avoid but that was due to getting alot of really bad filament from them about 3/4 years ago, They used to just resell the chinese stuff thats all over Ebay but I dont think they do that any more.
Personally I use Fillamentum and just grab a few rolls from Prusa every so often
Opublikowany : 27/11/2017 3:48 pm
Macca
(@macca)
I would second the recommendation for spannerhands, Richard is a great guy to deal with & fillamentum has been my go to for PLA for quite some time, I go through a lot of filament & it is constantly good & fairly priced for the excellent quality (Rigid ink is way too expensive)
Opublikowany : 27/11/2017 9:47 pm
patcooper
(@patcooper)
Thanks for the replies, first project will be with petg as a base unit to carry various other items.
Opublikowany : 29/11/2017 5:32 pm
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Checkout https://www.filaments.directory/ you can find all kind of filament properties, locations and even print profiles for some of them.
Opublikowany : 29/11/2017 5:35 pm
