filament sensor
Knickohr
(@knickohr)
Member Moderator
filament sensor
Hi !
Is the filament sensor of the MK3 be able to measure the diameter of the filament ?
What type of sensor is it ? Yes, it's a laser but how do they measure or detect ?
Maybe something like this is possible in the near future :
Thomas
Napsal : 26/10/2017 4:02 pm
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Re: filament sensor
Hi !
Thomas
it may work as the laser sensor scans the area and detects movements or objects. Check this out https://conorpeterson.wordpress.com/2010/06/04/optical-mouse-hacking-part-1/
Question is how you can program that and how good the resolution of the sensor is to be able to recognize < 0.05mm differences.
On the other side the quality of the filament diameters within +-0.05mm got so much better and this function may not be needed anymore.
Waldemar
Napsal : 26/10/2017 5:16 pm
ben.c5
(@ben-c5)
Re: filament sensor
based on the makerfaire interviews i think it is just a standard laser mouse sensor, capable of detecting presence and movement but not designed for measurement. are you specifically trying to continuously gauge and record the diameter to check for / correlate variance with print errors or machine failure? you might be interested in https://www.thingiverse.com/thing:454584
Napsal : 16/11/2017 1:07 am
Knickohr
(@knickohr)
Member Moderator
Re: filament sensor
Yes, this was the intension and the reason for writing this thread 😉
Thomas
Napsal : 16/11/2017 9:07 am
3d-gussner
(@3d-gussner)
Re: filament sensor
Thomas
Hi here some links:
http://forums.reprap.org/read.php?1,636034
http://diy3dprinting.blogspot.be/2014/01/diy-filament-diameter-sensor.html
Napsal : 16/11/2017 10:55 am
rotarypower101
(@rotarypower101)
Re: filament sensor
Silly thought... but I always had a idea it might be a concept to run two sets of ball bearings with spring tension pinching the filament in both X,Y axis and have a accurate distance sensor between bearing axis that would feed the offset values information back into the extrusion multiplier.
The small variance in good filament doesn't seem to be a problem, but I have read about those that require tighter tolerances seem to be affected by filament creep.
To have real time measurement seems like that would be a easy solution given the need.
Napsal : 16/11/2017 12:34 pm
Peter
(@peter-12)
Re: filament sensor
In this interview with Maker's Muse Jo mentions that mechanical sensors "grinds down" after a while. I'm guessing there is a way to design around that, but I wouldn't know how. 😀
Napsal : 16/11/2017 1:59 pm
rotarypower101
(@rotarypower101)
Re: filament sensor
Clearly I can't know...but
I believe they were referring to drag over implementations.
My guess would be a plastic micro switch...
The idea of using something made of a very hard metal, and only to measure diameter between two point of the filaments chord.
If a brass hobbed gear can maintain itself...I am sure a case hardend rolling bearing will suffice and not wear out prematurely.
If I understand your concern correctly?
And to elaborate on why the sensor Prusa use for fillement detection is good/ better than a microswitch, is that a photo sensor can be used to indicate "motion" that the filament is feeding at the proper rate, or at all....
A typical micro switch can only indicate that there is filament triggering the switch, and won't indicate jambs or skipping.
Napsal : 16/11/2017 3:00 pm
