Fail stats all 255 even after factory reset
jettoblack
(@jettoblack)
I noticed that going to Fail Stats shows this screen with 255 for all values.
A factory reset (all data) did not help, they are still the same.
Anyone else having this issue? Any suggestions?
Napsal : 08/12/2017 5:51 am
Paul Meyer
(@paul-meyer)
Re: Fail stats all 255 even after factory reset
Is it causing a problem? May just be a weird reset value. Start a print, cause a power loss, and see if it rolls over to 0.
Napsal : 08/12/2017 6:19 am
oliver.k3
(@oliver-k3)
Had the same thing. I caused a collision just to watch the shifted layer detection and it jumped then from 255 to 1
Napsal : 08/12/2017 8:44 am
ElBartoME
(@elbartome)
Firmware is still quite buggy...
My printer just restarts itself when I start the PID calibration.
Napsal : 08/12/2017 9:37 am
maxx78
(@maxx78)
Mine did that during the setup wizzard...
Napsal : 08/12/2017 12:53 pm
jettoblack
(@jettoblack)
I was able to get the Power failures and Crash detected numbers to rollover to 0 by intentionally causing those problems to happen. (Neat!)
But Filament fails remains at 255 no matter now many times I cut the filament and let it run out during a print. Perhaps it only increments on non-recoverable filament failures like a jam?
Napsal : 08/12/2017 3:02 pm
Peter
(@peter-12)
Looking through the firmware, it seems the entire eeprom on a new board is filled with 0xFF (255 decimal), I'm guessing they forgot to add code that sets these counters to 0 to the reset function.
Napsal : 09/12/2017 5:23 pm
Josef Průša
(@josef-prusa)
Member Admin
Ooops, I'll forward it to the dews 🙂
Founder and owner / Majitel a zakladatel
Napsal : 09/12/2017 7:05 pm
