e3D Volcano
truman.w
(@truman-w)
e3D Volcano
Has anyone got an e3D Volcano working with their mk3? I've tried messing with the firmware but it's refusing to compile. Any help would be greatly appreciated 🙂
Postato : 12/01/2018 6:01 am
Peter
(@peter-12)
Re: e3D Volcano
Did you find the links mentioned in this thread https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/how-to-compile-the-mk3-firmware--t13410.html
I didn't realize the volcano needed new firmware, I thought it was a slot-in replacement? Except for the physical modding needed, obviously. What changes to the firmware are necessary? Does it use a different thermistor?
Postato : 12/01/2018 7:43 am
Syrc
 Syrc
(@syrc)
Re: e3D Volcano
From my experience using a Volcano on my MK2s, the only major difference is the loss of 8mm on the Z axis. Everything else is the same as with a standard v6.
I never bothered correcting this in firmware, since the calibration v2 gcode handled it fine, but it does prevent using the Z calibration from the menu (nozzle crash). If the MK3's baked-in calibration handles like the v2 gcode (slow descent above 0,0, stopping when the probe picks up metal), it should just be a matter of changing the max Z height in the slicer.
Postato : 12/01/2018 8:38 am
truman.w
(@truman-w)
Re: e3D Volcano
Syrc, can you show me how you got around the issue (with your slicer settings?) I'm not quite sure I get what you mean. Thanks in advance 🙂
although I would like to have Z calibration for convenience hahaha I can live without it though
Postato : 13/01/2018 9:33 am
Syrc
 Syrc
(@syrc)
Re: e3D Volcano
Sorry, I forgot all about this thread until now. In Cura, I went into machine settings (settings -> printer -> manage printers -> machine settings), reduced the Z height by 8mm, and increased the gantry height by 8mm. For the most part, you don't even need to change these except for sequential printing, as the auto-calibration before a print will figure out how high the nozzle should be.
Postato : 19/01/2018 3:25 am
