Can’t print few files
israel.n
(@israel-n)
I have a few files that I've downloaded from thingiverse, when I'm trying to print them it fail (incomplete print). Frankly i get a message that the file is damaged but i repaired them the Prusa way but still the print fails. Any advice?
https://www.thingiverse.com/thing:1454048
Files numbers 011 gearmasfull, 011 gearmast, 013 lower base
Respondido : 25/03/2018 7:50 am
RH_Dreambox
(@rh_dreambox)
Re: Can’t print few files
Perhaps this one can help you?
HOW TO REPAIR CORRUPTED 3D MODELS FOR PRINTING
https://www.prusaprinters.org/#_ga=2.173919588.676488563.1513696153-2016033030.1513696153
Respondido : 25/03/2018 10:57 am
israel.n
(@israel-n)
I’ve tried that:
https://www.prusaprinters.org/repair-3d-models-errors/
But nothing
Respondido : 25/03/2018 12:08 pm
RH_Dreambox
(@rh_dreambox)
That was weird. I opened them in Simplify3D without any problems, but I get an error message in Prusa Slic3r.
I attach a file that is prepared (PLA 0.2 mm) in Simplify3D that you can test.
But if you think the problem in the center of the wheel depends on the STL file, I'm not entirely sure. It may also have other causes.
Respondido : 25/03/2018 12:39 pm
israel.n
(@israel-n)
Hi
Thanks
If u can please try print one of them in your prusa mk3 and look if it’s ok.
I want to be sure no something wrong with my printer
Thank you very much
Respondido : 25/03/2018 1:10 pm
israel.n
(@israel-n)
Now I try print with simplify3d prusa recommend seething (found in the forum) but the print fail again
Respondido : 26/03/2018 2:24 am
RH_Dreambox
(@rh_dreambox)
Here is my print done with Prusa Slic3r, PLA 0.2 mm and Prusa default settings.
So you may want to check your printer that it has the correct belt tension, so that the pulley wheels can rotate easily.
If you have changed any settings in Prusa Slic3r, reset them to original.
Respondido : 26/03/2018 10:06 am
RH_Dreambox
(@rh_dreambox)
I attached the code here also if it could not be attached to my PM.
Respondido : 28/03/2018 12:55 pm
