Can't even get to self test
I just built my I3 MK3 kit. All went well until power up. I get the language selector, I select English, I get "Original Prusa i3 Prusa Research" and the fans come on.
It then returns to the language selector. I've checked the wiring multiple times. I've no idea as to my next step. Right now, I've an expensive paperweight. Help!
Re: Can't even get to self test
Sounds like it is resetting.
Did you try a factory reset ?
http://help.prusa3d.com/38908-firmware-software/276545-factory-reset?from_search=18894248
if that does not help i would try the live chat
If you get the LCD panel out of the printed housing, do you still encounter this problem? I am thinking maybe something got stuck between the housing and reset button causing it to infinitely reset.
The reset instructions helped! Im starting the calibration now. Thank you!
