Bed Thermister
Jim Cook
(@jim-cook)
Bed Thermister
Does anyone know if the proper heated bed thermister is available from Digi-Key?
Respondido : 19/03/2018 11:39 pm
Re: Bed Thermister
I believe it is a Semitec 100K thermistor,
I don't see Semitec on the Digikey website
Regards Joan
Respondido : 20/03/2018 12:16 am
Jim Cook
(@jim-cook)
Re: Bed Thermister
Thanks Joan. I'll search.
Respondido : 20/03/2018 12:39 am
Jim Cook
(@jim-cook)
Re: Bed Thermister
A quick search found it on Amazon.
The one I have has a broken lead. That "leads" (pun intended) to the question: can I solder the lead and expect the thermister to work?
Respondido : 20/03/2018 12:44 am
Re: Bed Thermister
as long as the lead is visible from the thermistor bulb, you can re solder it for the heatbed
the heatbed usually only reaches about 100 centigrade,
solder has a higher melting point.
for hot end thermistors you are better using a crimp tube than solder
Respondido : 20/03/2018 2:12 am
