Bed level issues when doing a full bed print
Navcab4422
(@navcab4422)
I had a print that fills up the entire bed and seem to have places too low (front right) and too high (left) to print properly. Any suggestions?
Postato : 24/03/2018 10:27 pm
Brigandier
(@brigandier)
Re: Bed level issues when doing a full bed print
Yep: https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/-testers-needed-tpu-micro-springs--t15061.html
The above won't do anything for the pinda firmware issues, but getting it as close as possible helps.
My MK3 Parts: [Bowden] [New Shoes] [TPU Micro Springs]
Postato : 24/03/2018 10:30 pm
Peter L
(@peter-l)
You can also increase your first layer print height, which makes it a little more forgiving of imperfect bed geometry.
Postato : 25/03/2018 12:38 am
Navcab4422
(@navcab4422)
It's at 0.2 now what would you recommend?
Postato : 25/03/2018 4:28 am
Peter L
(@peter-l)
You can go up to your nozzle diameter. Try 0.3mm and see how that works.
Postato : 26/03/2018 6:06 pm
Jerry
(@jerry)
there is a bed level correction you can enter to raise / lower R L F B. I used that to average out approx the differences it is a journey to figure out not impossible.
Postato : 29/03/2018 12:22 am
