anyone had to jury rigg the X axis belt to keep it from rubbing
Azzatar
(@azzatar)
I had to add 2 washers to each motor mount screw to keep the belt from rubbing the orange housing and failing the self test. Did I do something wrong? has anyone else had this problem?
Publié : 01/01/2018 1:33 am
reid.b
(@reid-b)
Re: anyone had to jury rigg the X axis belt to keep it from rubbing
Are you sure you pushed the pulley all the way down onto the motor shaft?
Publié : 01/01/2018 1:36 am
Azzatar
(@azzatar)
yeah that was the first thing I checked. With out the washers it was actually twisting the belt and the rubbing from just the self test was starting to leave pieces of the belt on the housing
Publié : 01/01/2018 1:38 am
rufflez
(@rufflez)
Pretty sure the pully is backwards. Flip it around. I did the wrong thing originally as well.
Publié : 01/01/2018 1:43 am
Azzatar
(@azzatar)
well that would make sense I will give that a try and report back. That worked... :mrgreen: I just put my Donkey ears on.
Publié : 01/01/2018 1:44 am
rufflez
(@rufflez)
I did it during my build. So use to the fatter part being closer to the motor.
Publié : 01/01/2018 1:56 am
Bill
 Bill
(@bill-3)
Don't feel bad, I did the same thing during the build. Luckily I figured it out before moving on the next step. I thought they might want to emphasize the correct pulley placement in the directions since it is the opposite of the way the Y axis motor pulley is placed. That's why is made the mistake. When it was time to put the pulley on, I just looked at the Y axis motor and placed it the same way. Later, when I noticed the rubbing, I too had to re-do the step.
For those waiting to build.. FYI the Y axis motor pulley and the X axis motor pulley are installed exactly opposite of each other.
Publié : 01/01/2018 4:24 am
Neal
 Neal
(@neal)
Maybe a photo with the grub screw turned to the camera would have helped a bit.
Just a thought,
Neal
Publié : 02/01/2018 3:26 pm
Chris
(@chris-16)
me too but it took until the self test for me to figure it out. had fun switching the pulley around but did get it to work
Publié : 02/01/2018 4:18 pm
